alternator connections LS's & LQ's
i am considering using the bracketry setup (balancer, water pump, etc...) from a denali on my LS1. i have a few questions...
1.) will the position of the alternator clear the corvette fuel rail covers?
2.) are the alternator electrical connections the same for the LQ and LS engines?
3.) do you anticipate any other problems that i am overlooking?
thanks,
chevrev
thanks,
chevrev
No direct knowledge, but you need to get all the pulleys, especially the crank one due to offset dimensions which vary from the Corvette, Camaro, and truck. AC compressor mounting might be different
