My compressor is leaking oil but the ac still works.It looks like it's leaking from the back.There are 2 long bolts on the bottom and it looks like it's leaking from the bolt close to the steering rack.
Mine's about to give up the ghost as well; same problem. Mine started leaking oil about 25k miles ago. It'll eventually stop blowing cold. Solution: replace compressor.
Def, start shopping for a rebuilt or new compressor. If you change it before it breaks you may not have to buy the rest of the ****.
Accumaltor, dryer,evap........lines.....
I've located a new (used )compressor from a 2002 camaro being parted out.Will it work on my 98.I know the pcm wires on and 98 are different from 99 to 02.
