TD question
TD question
I plan on running a true dual settup over the rear axle. I want to run one over each side. I tried to search, but I got conflicting results. Is the upper panhard relocation kit for running both pipes over the passenger side, or is it for running one pipe over the driver side and one over the passenger?
That's what she said...
The relocation kit is for running both over the passenger side. Some people have gone one over each side, in which case you won't need the relocation bracket.
They usually run the driver side pipe UNDER the PHB support. I think Orangeapeel's duals are done this way.
BlackBADaSS02, You can very easily run both pipes (2 1/2 pipes) over the axle without a Panhard bar relocation kit. I've done it and so has so many others. I WOULD NOT move the Panhard bar. You DO NOT have to. As I said the two 2 1/2 inch pipes will go over the axle on the passangers side with everything in the stock location. Just have your muffler shop tec. bend the pipes to fit tha space. It should be no problem at all to do. The Panhad relocation kit is just another way for a company to make money. You DO NOT NEED TO MOVE IT TO INSTALL DUALS!!!
