quick exhaust questions
I read up on all the mod guides.for pacesetter off road, or jet hot off road both 1 3/4" I'll need 2 24" 02 extensions right? Also will the TSP off road Y fit the jet hot 1 3/4 off road header, because it fits the hooker and the hooker and Jet hot are of the same design. Also does anyone think I would benefit from a jet hot over the pacesetter? I have read they all perform similar.
ЯєŧąяĐ Єl¡m¡иąŧøя ™
That's what she said...
You will be very pleased with the Pacesetters. They are cheap and damn near install themselves. We also KNOW that the TSP y-pipes will fit pacesetters no problem, however, I'd run the pacesetter y-pipe instead of the TSP unit for ground clearance reasons.
I think that orange meant you need 2 24" O2 extensions for the FRONT O2's, he must be pulling an all nighter/dayer again.
I must also suggest a set of poly motor mounts to top her off with, it will keep your motor steady and stop the vibrations/banging before they start. $50 from thunder, but TSP may sell them too.
