Fast 90 mm or ls6
Fast 90 mm or ls6
Hi
I,m planning to buy new intake what is your advise for me to buy a fast 90 mm or ls6 for my 2000 Z28
my mods are:
Hot cam kit
LT Flowtech headers & Y pipe
SLP cat back
SLP CAI
ASP carnk pulley
my mods are:
Hot cam kit
SLP cat back
SLP CAI
ASP carnk pulley
If you have the money a FAST 90mm is the way to go. But you will need a 90mm throttle body.
The LS6 Intake is a step up from the LS1 intake, but it will work with your stock throttle body.
For the FAST you will be in the area of $1100-$1300...
it all depends on your future plans. if you are eventually going to a huge cam or a bigger motor, then go with the fast90. on the other side of that. there are people with bigger cube motors that are still using the LS6 intake. and making great power. it is all in what you want to spend. you can either spend 300 bux and get an ls6 and bolt back on your stock TB. or go with the Fast and have to spend over 1000 to get the intake and the matching TB.
If those are your only mods, you will lose low end/gain top end power with the FAST 90. A ported FAST 90 might get you better gains, although I've yet to see one of those on a cam-only setup (especially a baby cam like that).
