Help! No Room for TD exhaust?? Advice ?
Old 08-17-2006, 02:25 PM
Red Cell's Avatar
Default Help! No Room for TD exhaust?? Advice ?
HELP!
I need new exhaust and have researched the search... my car is a 1998 6speed camaro ss.
Problem: not much room left underneath the car for exhaust..
I have the UMI body mounted torque Arm.
QTP Long tubes
SLP double diamond weld-in sub frame connectors.
4" driveshaft.
ford 9" rear end.
will have a new engine soon with 800+ hp
whats the best way to go for an exhaust setup?
Stainless 3" oval tubes?? Dr Gas?
A true Dual setup that dumps before the rear axle or side exit?..
if possible, id like to get 2 electric cutouts installed at the header ends..
and use 2 sweet thunder mufflers. no cats.
it dosent look good for me trying to get a True Dual exhaust setup under here, especially an x-pipe config.
Unless someone here has a great Idea on design. or can point me in the right direction
Im just asking if someone here has a similar setup that has succeded in getting true duals in.
any advice or posted pics would be really appreciated!
Thank you
Old 08-19-2006, 02:03 AM
WILWAXU's Avatar
to the top
Old 08-19-2006, 05:06 AM
barracuda_440's Avatar
my buddy had a similar problem, so they ran a 3inch H pipe setup that fits great. maybe i can get some pics for u.
