Header bolts
Old 08-25-2006, 02:27 PM
nexvctm2001ss's Avatar
Default Header bolts
Do I need to use different header bolts when changing the headers or can I reuse the stockers????
RrCoX22's Avatar
reuse the stockers and you'll be fine
Old 08-25-2006, 02:28 PM
Thanks just checking
Old 08-25-2006, 03:05 PM
Divergent Lightning's Avatar
Just be sure to re-torque bolts after a little bit of use as they will back out a little bit and cause leaks.
Old 08-25-2006, 03:21 PM
BlackBADaSS02's Avatar
You can reuse the stockers. i choose to go with the stage 8 locking header bolts so I wouldn't have to worry about them backing out.
Old 08-25-2006, 03:29 PM
RrCoX22's Avatar
you guys must not be torquing them down good enough.... 18 lb ft and start with the middle two and work your way outwards
Old 08-25-2006, 08:37 PM
TORCHD 02 TA's Avatar
werd
that is what i am doing when i get my LTs installed in about 1 week.. everyone says to reuse stockers.. all my friends that did that, they retightened them like 5 times a month.
up to you
