What else Do I NEed?
Old 08-26-2006, 02:55 PM
Splitz's Avatar
Default What else Do I NEed?
Car is stock....
Planning on Buying Corsa Cat-Back, Pacetters LT, and TSP's Catted Y.....do I need the O2 extensions as well?
What do I absolutly need to finish the setup? Gaskets? I want this to go as smooth as possible. Unbolt and bolt on but want everyting ahead of time before I start tearing into the car.
Thanks!
Old 08-26-2006, 03:02 PM
Starz T/A 17's Avatar
yea you will need 02 extensions, also you may need 02 sims im not sure if the TSP catted Y pipe has the 02 bungs for the rear
Old 08-26-2006, 03:08 PM
RrCoX22's Avatar
and to add.... a set of new GM exhaust mani. gaskets
Old 08-26-2006, 04:01 PM
Splitz's Avatar
I assume 2 manifold gaskets right? What's the GM's part number?
Old 08-26-2006, 07:42 PM
Ive done header install's on 2 different cars and both times we just reused the old gaskets their metal so 90% of the time they will still be good and you can reuse them
Old 08-26-2006, 07:47 PM
Beasst8's Avatar
Yeah, I reused my stock gaskets. I had 32K on the car then.
Old 08-26-2006, 07:52 PM
lastcall190's Avatar
There's a corsa in the FS section right now for pretty cheap, just an FYI. As for what else? Everyone pretty much covered it Good luck and have fun on the install
-J
