ASP pulley or other brand
How much HP are ASP pulleys worth?Do you get charging issues like dimming lights low voltage at a stop light? Are they worth it?How much are they and where can I but them?About 8 years ago had a95 mustang gt and put pulleys on and had alot of chargining issues is it the same on f-body?Sorry for all the questions just wanted to know if the HP would be worth the charging issues(if any).
thanks john
thanks john
I have an asp pulley, I don't really notice any gain at WOT but putting around town feels like theres more torque, and it revs alittle quicker in neutral.
When I first start the car there isn't much charge, but after the first shift into 2nd gear there are no issues whatsoever with charging, even when it gets to stoplights, I would recommend one if you have the spare cash, since you save wear and tear on your accessories also.
The alt will not be able to keep up with the electrical load such as E fans, and A/C sitting at a stop light idling. I even have the alt overdrive pulley. Not a big problem, I just have to make it idle at 1100 to keep voltage at or above 13.
