need help installing e/cutout
They're easy...installed a couple different brands. Make sure it's welded in the correct position (if not already done) and post up if you have any questions after reviewing the instructions.
You do, just need clearance for the motor portion/angle of the cutout so it doesn't hit the bottom of the car. Probably OK if it's under the rear seat.
