Gaskets w/ LS6 Coolant Tubes?
Well I noticed that the LS6 coolant tubes, the ones that cross over from one head to the other, have o-rings on them, while the stock LS1 coolant tubes dont. So are you guys still using the coolant gaskets/seals(12551933)? I'd imagine not, but I'd like to see what others are doing. I am planning on running two front LS6 coolant tubes in case you were wondering.
LS1TECH Sponsor
Originally Posted by joshp14
They switched to a new design. The old design was just the tube with flat gaskets....the new style has rubber o-rings that come with the tube.
Originally Posted by ShevrolayZ28
I don't know. But don't forget to block off the holes in the back of the heads. And do it before you install the heads!
