ls6 manifold vs edelbrock victor jr manifold???
which intake manifold is a better set up over all for a high hp engine??? i was told that you can get 50 hp from the edelbrock??? is that true??? i have a ls6 manifold right now should i keep it or upgrade to the edelbrock?? any of you guys running the edelbrock setup???
That's what she said...
50hp is rediculous. You will loose some bottom end, but probably gain some on the top. They are kind of hard to fit under the cowl, and you need an elbow/new throttle body to make it work.
...if I'm thinking of the right thing.
Do a search, you should find some info on what others have done.
