Bell mouth adaptors on true duals / flowmasters?
As per the introduction to exhaust sticky, it is recommended to use a muffler about 1 inch larger in diameter than the piping and connect them with a bellmouth adaptor as per the illustration to get a little bit more under the curve power. However I have heard nothing from anyone who has actually applied this to their set-up. I found nothing using the search.
My planned set up is QTP headers, h-pipe, 2.5 tubing over the axel, and flowmaster single chambers. Would this be a good application for said set-up? Why or why not? Also for those using single chambered flowmasters, which length are you running? I have seen several different options.
