PCV question
Old 10-24-2006, 10:06 PM
saleboat92's Avatar
Default PCV question
I am having problems with my cars ideling and it stalls when I give it gass, I replaced the 02 sensers. I am now thinking it is my PCV valve. I moved it around and at first I thought i felt it change the idel. My question is has any one had to change one and what wher your symtoms???????
Old 10-25-2006, 03:23 AM
ATL HAWK's Avatar
Real easy to change and is cheap. Go to your local gmc,chevy,pontiac,cadillac dealer and get this pcv valve. Read this on ws6store.com and have seen a few comments that this pcv valve is much better. See part # below. Cost $6.75 AT A LOCAL CHEVY DEALER.
98-02 LS1 GM PCV Valve (New Design)
[12572717] $6.99
As many of you know, the PCV system on the 98-02 LS1's isnt exactly the greatest system on the planet.....burning up to 1 quart every 3K miles. After many complaints, GM finally issed a service bulletin to address this issue on all of the GEN 3 engines. They have replaced the ball-type PCV valve with a new fixed orifice design that is used in the GM trucks. This design will help reduce oil-consumption on your LS1.
New GM part. Please allow 1-2 days to ship out.
Old 10-25-2006, 03:34 AM
saleboat92's Avatar
I appreciate the feedback. I found a write up on line from misterfixit.com/pcvvalve.htm about symptoms. It stated that symptoms wher rough idle or stalling which is the problem I am haveing so hopefuly this will fix my problem
Old 10-25-2006, 03:44 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Good luck on making it work. I had a problem like that and finally changed to the LS6 style PCV and was working great.
Old 10-25-2006, 11:19 AM
ChaseSS's Avatar
i have a great write up on it but its more than 2mb so I don't know how to post it up on here... i can email it to you if you want, let me know
Old 10-25-2006, 12:29 PM
saleboat92's Avatar
I have already done the ls6 valley cover swap, but if the article is on something else I would love to read it saleboat@stjoelive.com Thanks
Old 10-25-2006, 03:14 PM
Cerebrex's Avatar
Take that **** off! Down with PCV!
