msd 2 step & ignition
Old 10-26-2006, 03:37 PM
stdjsw311's Avatar
Default msd 2 step & ignition
hey i am looking into doing a 2 step module on my m6 z28 2000. i want to do it with line lock too. has anyone done this sucessfully??? if so i would like to see some sort of wiring diagram. i am tired of getting to the line and not knowing exactly what rpm i am at when i launch and i would like to become more consistant!
another ? is that how will a msd ignition work with the computer??? something like a digital 6 or a 6al
Old 10-26-2006, 05:30 PM
GR33N GoblinM6's Avatar
question... what HP are you pushing? Are you using NO2? Boosted?
Old 10-27-2006, 01:20 PM
stdjsw311's Avatar
425 on motor + 150-200 n2o
Old 10-27-2006, 02:30 PM
stock ignition is more than enough for what you are pushing.. dont waste time with the MSD boxes.. you wont see anything by using them.. I have used them in the past and my cars showed a slightly better idle, for about a month... then all the problems start, hard starting, detonation, ect.
pulled the MSD off.. car ran awesome.. I have owned 6 camaro's 2 of which I used the boxes and blaster coils... not worth it at all.
Old 10-27-2006, 05:36 PM
NemeSS's Avatar
the msd ls1 ignition controller has abuilt in 2 step, it is mainly to control, the ignition on a carburated ls1, but it can also be used to control spark and use the 2 step on a efi ls1 in conjuction with the stock pcm, as for use with n20
or the 2 step feature.
Old 10-27-2006, 09:38 PM
stdjsw311's Avatar
so still wondering how it is done for the 2 step wiring wise
