Look at my freeze frame tell me whats wrong
Old 10-30-2006, 05:00 PM
REDSS98's Avatar
Default Look at my freeze frame tell me whats wrong
Freeze Fram Data
PID Description Unit Value
DCT for which freeze fram was stored P0300
Fuel system 1 status Closed loop
Fuel system 2 status Closed loop
Calculated load value 5.88%
Egine coolant temp. 198
Short term fuel trim-Bank1 -0.78%
Long term fuel trim-Bank 1 3.13%
Short term fuel trim-Bank2 -3.13%
Long term fuel trim-Bank2 0.00%
Intake Manifold Absolute Pressure 10.9inHg
Engine RPM 1438.25rpm
Vehicle Speed sensor 41.9mph
Air Flow Rate From Mass Flow Air Sensor 2.315lb/min
Absolute Throttle Position 10.20%
Old 10-30-2006, 05:18 PM
SSpdDmon's Avatar
Do you have an aftermarket converter??? That has a tendency sometimes to set off a misfire code. You can desensitize the misfire tables in the tune if you have the right software.
Old 10-30-2006, 05:30 PM
REDSS98's Avatar
Do not have any converters Stock ls1 with headers and loud mouth
Old 10-30-2006, 05:31 PM
SSpdDmon's Avatar
Not catalytic converter. Stall converter in the trans (ie - Yank3600)...
Old 10-30-2006, 05:33 PM
REDSS98's Avatar
I have a 6 speed
Quick Reply: Look at my freeze frame tell me whats wrong
