Valve cover spacers?
Has anyone used them? Thunder racing sells them and I was wondering if they are prone to leaking. Just installed comps pro magnum rockers and the drivers side poly locks hold the cover up a 1/4" despite comps advertising that they will fit under stock valve covers with no machinig or modifications.
I don't want to remove the PCV splash tray as it dosen't use/suck up any oil into the intake manifold. Removing this might cause it to need a catch can and I am trying to avoid this.
Any thoughts?
Any thoughts?
I have Pro Mags on two trucks. I ground the rivets off of the sheet metal deflector to get the cover to fit. I don't think that deflector does a whole lot. Have you seen the cost of the those spacers? At that price the die grinder came off of the shelf real quick. I don't have a problem with crankcase pressure, but there's nothing wrong with running a catch can. Top Fuel has one for each bank.
