Looking for dynomouth sound clips
Old 11-14-2006, 10:23 PM
BayAreaSS's Avatar
Default Looking for dynomouth sound clips
I've been on ls1sounds and they dont have a good selection of dynomouth clips.
So can you guys post some clips?
I'm also open to different bullets in the I-pipe
Thanks
Old 11-15-2006, 01:43 AM
BuBbABFP's Avatar
Go here thyre is a couple.
http://www.ls1sounds.com/dynomouth.htm
Old 11-15-2006, 01:56 AM
BayAreaSS's Avatar
I've been there and checked it out Thanks.
Old 11-15-2006, 05:52 AM
300bhp/ton's Avatar
Well depending on what Dynomax bullet you go with a TSP Rumbler (Not Rumbler X) is basically a mild steel Loudmouth with a Dynomax bullet (aka Dynomouth).
I hear more than a few complaining of drone with this setup.
When I was looking into it the Borla XR-1 seemed to be the preferred choice but they are pricey.
A Magnamouth (search this forum) would be my first choice if I was every to swap out the LM resonator (unlikely).
I just replaced my Dynomax bullet with this Magnaflow bullet, its only 4"" round. I got the part# off of this site. Part# is MPE-14419 from Summit.
Old 11-15-2006, 05:53 AM
300bhp/ton's Avatar
Or you could try going for a "Classic Chambered Exhaust" Powerstick. Use Google to find them.
However to aviod rasp and give tone you would probably want the muffler to be as long as possible, so basically the entire length of the I pipe if you plan on dumping it.
Old 11-15-2006, 03:08 PM
BayAreaSS's Avatar
ok i'll check into those set ups. Thanks for all the help
