Will Magnaflow for 95 Z28, fit my 98 Trans Am?
Old 11-22-2006, 09:09 PM
CT Hotness
lilstephsls1's Avatar
Default Will Magnaflow for 95 Z28, fit my 98 Trans Am?
I tried to do a search and came up short so I appologize ahead of time if this is a double post, but I am looking for a Magnaflow catback for my 98 Trans Am. I found a cheap used maganflow off a 95 Z28 and was wondering if this would fit my car or would require modification? Thanks everyone!!
Old 11-22-2006, 09:26 PM
jdo6696's Avatar
everything should fit, my brother used his SLP firehawk exhaust off his '96 Ram Air Formula on his '01 T/A and it fit fine. connections should be the same and the body and axle routing didn't change from the LT1 to the LS1, so you should be fine.
I am sure others will chime in if I am wrong...
Old 11-22-2006, 10:50 PM
Cop Car's Avatar
yes it should be fine, if i remeber right they are the same, then the y pipes are vastly diffrent
Old 11-23-2006, 09:37 PM
CT Hotness
Great guys, thanks!!
Old 11-23-2006, 09:42 PM
jdo6696's Avatar
u r welcome.
