Aluminum intake worth anything?
I've got an '04 Vette. This winter I'm putting on some stage 1 ported LS6 heads with sodium valves, LPE GT2 cam and longtubes. The car came with an LS6 intake. Would putting a Lingenfelter aluminum intake buy me anything? The car will not see N2O. I'm also concerned if the aluminum intake might heat soak more than the factory composite one.
Thanks
Thanks
Originally Posted by jpat1023
Yep, that is correct.
Thanks again, Tom
+1 on staying with the ls6. An aluminum intake manifold suffers from heatsoak. It has been discussed many times on this site and others. I'm sure if you search for it you can find all the theories you want...
