brass inserts
brass inserts
can you get them to put in the corvette ls6 intakes? i can get a corvette ls6 intake just don't want to unless i can get my throttle cable bracket to bolt to it.
yes, used search.
yes, used search.
What are you talking about?? Please elaborate because your post doesn't make any sense. Are you trying to put an insert between your intake and T/b, sort of like a maf screen? Please explain what you need help with.
i'll try again. you know where the throttle cable bracket bolts to the intake just behind the TB???? the corvette LS6 intake does not have the brass inserts already pressed into it to bolt the throttle cable bracket to it because the corvette is fly-by-wire. so, before i go and buy a corvette LS6 intake, i need to know if we can get the brass inserts that go into the intake, so you can bolt the throttle cable bracket to it.
that any clearer??
that any clearer??
Originally Posted by transAm-98
they all come with those provisions for the Throttle Cable bracket
