I give up... part numbers for a ls6 intake to a ls1 coolant bypass #
hello i have been serching for the part numbers for the coolant plugs and the front bypass hose for my ls1 because i am installing a ls6 intake now. anywho i would like to order the parts for GMpartsdirect.com. i can find some old part numbers that dont work. so if anyone can help it would be much appriceated.
thanks, joe
thanks, joe
LS6 coolant rossover pipe: 12568478
LS1/LS6 steam pipe plugs: 12562788
I'd personally run two of the crossover pipes, one in back and one in the front, this way the back of the heads get cooled also. Just run a piece of 1/4" coolant hose from the back crossover to the front, and use a T-fitting to connect it to the front pipe. This is what I did on my 427 and it worked awesome!
