SLP LM question
SLP LM question
I just ordered an SLP Loudmouth for my 02 Formula. Does the kit come with decent installation instructions? And/or does anyone have a link to an installation guide? I checked installuniversity and projectransam but neither spoke specifically of the SLP, only Borla. This will be my first exhaust installation and while I read it isnt too hard I want to make sure its done right, so any tips anybody has would be great.
the LM is really easy to install, i have one on my camaro and it only took maby about an hour taking my time and making several short cuts, you will need a sawsall and a can of wd40 for sure! when you make your cut in the I-pipe(the pipe that rune down the middle) make sure that you dont cut too short, so if you have to cut it so thats its too long, just make several small cuts until you reach the right length, it may take some extra time, but its well worth it. i dont know if SLP sends the kit with u-bolts or band clamps, but i suggest using band claps because i used u-bolts and i have some slight leaks, but its nothing tht hurts preformance, it justs sounds a little airy. hope this helps!
