Corsas Dont Fit Td's Ends?
Old 02-22-2007, 07:48 PM
sickws698's Avatar
Default Corsas Dont Fit Td's Ends?
I just got my corsa clones in...Look amazing! but they dont fit the end of my magnaflow bullits( 2.5) now i thought the corsa were 2.5 also, either way what do i have too do in order to make them fit? or can i just slide them in there a little and weld alot around it? cause they are barlly too small
Old 02-22-2007, 07:53 PM
Order 66's Avatar
Your magnaflow mufflers have slip fit 2.5". Meaning that the bullet slips over 2.5" pipe.
Old 02-22-2007, 07:54 PM
sickws698's Avatar
so thats not bad that the ends of my corsa's slide into my bullit a little ?
Old 02-22-2007, 09:05 PM
02trns_am's Avatar
Nope I think if you just slide them in a little and weld them up it would work fine.
Old 02-22-2007, 09:09 PM
dpw41285's Avatar
so the tips slide into the bullit? whynot have the exhaust shop make you a little reducer so it seals correctly then you can weld that
Old 02-24-2007, 09:26 PM
JpxZ28's Avatar
im not sure about the clones but the regular corsa's are 3.5's aren't they?
Old 02-24-2007, 10:07 PM
ls2 bait's Avatar
real corsas are made to slip fit over a 3" pipe.
