Has anyone seen/tried this kit?
Looking at some systems on Summit, and I ran across this one..
http://store.summitracing.com/partde...5&autoview=sku
It looks like it might fit with my setup, although I dont think it will clear the gas tank. If I cut the humps out, and run pipes UNDER the axle, does anyone think it will work? Do you think it will bolt to QTP lt's?
That's what she said...
You'd have to do some serious customizin' to make it fit.
The pipe leaving the driver side header either has to dip down and miss the body support, or you have to cut out the body support (and move the fuel lines). Also, those mufflers would be hell to fit under the back seats.
You're better off using the TSP duals, even ordering them without mufflers if you want to run different ones and go under the axle.
Just buy an X-pipe and mufflers of your choice and have a muffler shop fab up the rest. I printed off some pics of a TD setup I liked and took it with me b/c most shops will say it's impossible to put TDs on these cars.
