help manifolds help help help
Old 03-10-2007, 08:59 PM
99zmaro's Avatar
Default help manifolds help help help
need quick answer preferrably but do you take passenger side manifold off from top or from bottom as the oil dipstick goes through middle of it thanks
Old 03-10-2007, 09:00 PM
JDPZ28's Avatar
out the bottom. unbolt the dipstick and pull it out to get it out of the way. It's only held in by 1 bolt on the side of the head.
Old 03-10-2007, 09:01 PM
99zmaro's Avatar
did that but its still there that just holds it against head right it goes down into engine does it just pull out or what
Old 03-10-2007, 09:05 PM
JDPZ28's Avatar
Yes it pulls out. It's in there pretty tight. Take out the dipstick and get a pair of pliers if you need to and pull the tubing out.
99zmaro's Avatar
okay thanks a lot
Old 03-10-2007, 09:06 PM
Tainted's Avatar
heres a hint. everything goes in and out of the bottom
Old 03-10-2007, 09:35 PM
99zmaro's Avatar
thanks a lot got all the old out today in oo bout 5 hours haha now im hoping i can get new installed without any major problems
