crank position sensor??? please help.
Old 03-16-2007, 07:16 PM
1320 killer's Avatar
Default crank position sensor??? please help.
I am not sue if this is the right forum for this question. If not I apologize. I think I am having a problem with my crank position sensor, So my question is, Is there any way for me to check and see if my sensor is good or not? Thank you in advance for any posts that can help.
Old 03-16-2007, 07:23 PM
2001NBMZ28's Avatar
If you have the code look it up at www.gearchatter.com If it's bad and you replace it believe you need to do a relearn.
Old 03-16-2007, 07:27 PM
That's what I thought also but, it is not shooting any codes. Is there any other way to test it?
Old 03-16-2007, 07:41 PM
2001NBMZ28's Avatar
Don't know...maybe look up P0336 or P0335 and see if anything fits your situation?
Old 03-17-2007, 05:15 PM
Well, I changed the crank position sensor and it still has the same problem I think I have a bent or stuck valve. thanks for your suggestions guys
Old 03-17-2007, 07:55 PM
AlexLs1's Avatar
I kept throwing a crank sensor code it kept coming back.....Turned out that these two wires on the passenger side were rubbing against the header, causing that code to throw its self.
Good Luck with the repairs.
Quick Reply: crank position sensor??? please help.
