TPS sensor O-ring gasket?
Old 03-27-2007, 09:14 AM
RAGEman's Avatar
Default TPS sensor O-ring gasket?
Hi, folks. I'm posting this question in an effort to save myself from having to pull the TB back off this afternoon after work.
I installed a performancethrottlebodies.com TB yesterday, and since then am having trouble with my idle. The idle is erratic, high (fast), and slow to descend. According to Eric Berger's site, there is an o-ring gasket on both the IAC sensor and the TPS. I recall re-installing the one on the IAC sensor, but not on the TPS. Would a missing TPS o-ring cause my idle problems? Thanks in advance.
Old 03-27-2007, 11:26 AM
Arcolog2's Avatar
It could very well let a little air in yes.
Good luck finding a replacement o-ring for that. I gave up rather quickly on the IAC and used some RTV
Quick Reply: TPS sensor O-ring gasket?
