What Do U need for Header install (Pacesetter)
What do you need to buy besides the LT headers? Do U need new header bolts, new y-pipe or stock OK, extended O2 sensor, etc.? This is my first time, so all help is appreciated
Headers come with bolts, gaskets, a roll of wire and butt splices for the O2's.
Y pipe comes with clamps.
I ordered from Maryland Speed, they have an option box when you order that allows you to select O2 extensions with plugs, 24" for $36.
I ordered from them because you click on headers and all the options are right there, you don't have to search the whole site for the other stuff.
Do Not use the gaskets and wire that come with the headers.
Get.
GM stock Gaskets.
O2 Sims.
2-24 O2 extension.
I used Stage 8 Header Bolts.
10mm ratchet wrench to remove stock header bolts.
11mm ratchet wrench if using Stage 8 Bolts.
Might want to replace your plugs and wires during the install.
Get.
GM stock Gaskets.
O2 Sims.
2-24 O2 extension.
Call TSP and tell them you want to put pacesetters on your car. I beleive they have the cheapest prices on them.
I just got the coated race headers, TSP O/R Y pipe, O2 extensions, TR6 plugs and MSD wires, and an EGR plug for under $700 shipped. That's everything you need to put pacesetters on your car..........except for a lift
Reuse the old gaskets and front O2 sensors and the O/R Y pipe comes with 2 band clamps for the Headers to Ypipe connection and regular U bolt clamps to assemble the Y pipe. I'm gonna get mine on with the U bolt clamps and then take it down and have it welded.
I have a question about the pacesetter's. I had them on my LT1 with the ORY and they tucked underneath really close and the damn y pipe would hit my floorboard. Does it do the same thing on the LS1's?
yeah, you could make your own 02 extensions with the wire that comes with the kit......but don't use the walmart but connectors. Do it the right way and solder the connections.
Or, get some O2 sensor extensions and be done with it.
If you are installing these your self, get the arp header studs and save your self a big headache. Also if you have high mileage on your car I would recommend getting a new set of gm metal header gaskets as well. As far as the wires with the pace setters if you can solder and take your time you will save some money on the extentions. either way if you get the studs or us the bolts they come with do not forget to ANTISEIZE THE BOLTS !!!!
Appreciate the input guys. Got the Pasesetter LTs Armor Coat, 2-24" extension, lock header bolts, 2 o2 simulators and ORY. Did I do a bigg no no going without cats-cop wise? In Florida by he way and setup is going on a 02 WS6 with 28K
If the headers came with copper gaskets instead of the older paper versions, you can use those. Nothing wrong with re-using the stock ones though. Then you could sell the new copper ones.
Here is everything (i think) that I've gathered up to do my header install
Headers
ORY
spark plugs
header gaskets from GM
bosch 13111 o2's (not sure if those are the numbers, its been a while)
a couple band clamps
some anti seize for header bolts
expansion plug for egr in intake mani
I think thats it. There may be a couple things I forgot but thats the jist of it.
Headers
ORY
spark plugs
