mounting coil packs
mounting coil packs
im converting my bbc to ls1 coils and need to know if they require grounding or any kind of vibration isolation mounts. its going to be on a solid roller 468 with a big cam so theres going to be plenty of vibration. the coils are the truck coils with the little heat sinks on the back.
no,most just use a generic bracket,Rick made a bracket out of sheet metal for someone elses car.heres a pic of them mounted with a generic bracket
https://ls1tech.com/forums/attachmen...chmentid=88413
if you had to could u mount them to the cowl or the body on each side?
im going to mount them to my valve covers. i dont plan to use the stock brackets, however i do have some. i planed to just drill/tap the VC directly and use spacers to hold the coils up off the cover.
so they do not need to be grounded and they will live ok solid mounted to my valvecovers? like i said this is a big cam motor with motor plates so there is a fair amount of vibration.
heres what its going on. im going to mill the letters off the valvecovers.
