Valley/Knock Sensor Cover Bolts
Old 04-06-2007, 07:29 AM
mike s.'s Avatar
Default Valley/Knock Sensor Cover Bolts
Has anyone seen the LS1 knocksensor cover with Flat Head Socket Cap Screws? I was looking for one and I cannot find it, but I know I saw one in a mag somewhere. I was thinking of getting a counter sink and possibly doing it myself, but I'm worried that it might not seal if too much material is removed.
Anyone Done this before?
Old 04-06-2007, 09:34 AM
Ferocity02's Avatar
Why...............?
Old 04-06-2007, 11:28 AM
See5's Avatar
The bolts you refer to come with the FAST intake, I think. They are used because there is danger of the FAST bottoming out on standard bolts.
Old 04-06-2007, 01:46 PM
mike s.'s Avatar
Originally Posted by Ferocity02
Why...............?
I have a 383 LS1 I am building, I like the way the bolts look flush. Some people like to pretty up the outside, I like to pretty up the inside, even if it is covered by the intake. Thats why.
Mike
Old 04-09-2007, 02:53 PM
radkon's Avatar
Thats it, they are "button head" allen wrench bolts. 10 of them. I suppose you can get the exact dimensions (length and thread pitch) or just by them from FAST. They sell the hardware kit by itself for like $25.
Old 04-09-2007, 06:43 PM
mike s.'s Avatar
They looked like they were counter sunk from the photo I saw, but if they are button head they can't be. I am working with an extra valley cover I have to see if it can be counter sunk to use the flat head cap screws. FYI, if you need these bolts they are M8s (i think) with the common thread pitch, nothing special, measure the length in mm and you have all the specs. I would not use fast for just the bolts, go to Fastenal, they have all these fasteners in stock, and even in stainless as well, and I know its cheaper than $25.
I still dont see how the button heads get you all that much more room, it must be a very small interferance.
Old 04-10-2007, 09:31 AM
radkon's Avatar
They are only a fraction shorter (maybe 3~4mm).
From the FAST install guide they are M8 30mm long (no thread pitch spec'ed)
