attn LTs and TDs all the way back... come inside
hey everyone, i was wondering if it would be possible to get a set of lts, with an x pipe, preferably 3 ", and run all the way to the back of the car, over or under. if the shop is good then they will be able to give me the clearance i need, either way. my question is would this be able to all be done for 1000 dollars?
my car is a completely stock 99 ss. not lowered, but has anybody run into that big of problems? how much labor would a shop usually charge to run an x pipe all the way to the back? has anyone done this and been able to use subframe connectors and other various suspension modifications?
have you read in the stickys i rember reading something about someone doing 3" and going all the way to the back. but if your going to get a good set of lts they will cost you around $300 or more and the sshop that is doing my X dumped is charging $700 and thats stainless, high flows, and morso spyral. take it how you want but dont give in to the shop saying what they want.
just try a 2.5 inch xpipe all the way back. That would be nice. And unless your making a ton of power you wont notice the difference in 2.5 to 3 inch.
and if you lower your car at all you will get clearance problems. I got sportlines and i scrape everything. But i do need new struts
