POS Serpentine belt problems..HELP!!!!
Hey guys, im having a problem with my serpentine belt. It keeps coming off for some reason. I replaced the belt with a new one because i thought maybe the old belt got stretched out. So i swapped them and its still doing it. It seems like it does it when i go WOT in the car. Im thinking it might be my idler pulley or possibly even the crank pulley, if anyone has advice PLEASE help me out, im desperate. Thanks Alot.
JacobK
JacobK
I have the Magnuson blower on my car and every time I would romp on my car, it would throw the belt. After calling Magnuson, I found out that there is an update that runs a bolt through the tensioner to a bracket which is in turn bolted to the head. It quit tossing the belt until last week it ripped the idler pulley off including part of the big aluminum bracket. I pulled it out, tig welded the crap out of the bracket and am back in business for now. I would make sure all pulleys aligned, make sure no bearings are gone in idler or any other pulley with the belt off and check the tensioner for deflection under load.
