ARP header studs
ARP header studs
Anyone use these? Is there enough room to get the header in with engine in car? I'm putting on Kooks 1 7/8's
I know they are expensive and I know the stockers work fine. Just getting lazy and if they work it would make the install easier and it seems like I'm always taking them on and off.
Bobby
Bobby
I found I couldn't put them all in first, but could get in enough to hand the header and the gasket and then screwed the rest in after. Make sure you use the ARP Moly Lube, as stainless into aluminum can have galvanic issues so coat them liberally prior to installing.
