Easy questions about Magnaflow?
1. 15684 is this the correct exhaust kit for 98 - 02 f-bodies?
guys i will buy magnaflow but the problem is if i buy whole kit(pipes, muffler, etc) shipping will be very high (internatioal) so what i think is, do they sell the same muffler individually? if yes, it will be cheaper to buy only muffler and have this pipe work(3 inch or whatever) done here in Turkey, as labour is quite cheap compared to America so any ideas guys?
thanks in advance
thanks in advance
Yeah, 15684 is the right part number.
I'm not sure if they have separate mufflers with a single inlet on the passenger side and dual outlets on each side.
Magnaflow mufflers usually run anywhere from $70-80 for just a standard single inlet/outlet. However, you have to take into account the fact that you will need over-the-axle piping work done. From my experience that's generally not cheap to have done right. Looks like your decision depends on whether or not you know a good shop and how much shipping will cost you....
