cooler thermostat?
cooler thermostat?
I'm having my car tuned and i figure while im at it i might as well have the fans turned down and throw in a coller thermostat...
is it worth it? and should i run the 160 or the 180 one?
some say the ls1 needs heat, but cooler engines tend to work more effeciently, ever notice how quick the car feels after startup, i gotta 160 but i think either is better than the stock hot one
Don't forget that the cooler your engine is, the longer it will take for your oil to heat up to the proper level. I had my fans recalibrated by my PCM tuner to keep the coolant below 200, and there's a noticeable difference.
ok, ive searched around a little today and decided to go with the 160... where should i have the fans turned to 180-185 seems to be the popular.. what do you al think?
