Super Victor LS1 vs. GMPP Carb style EFI
Im looking to change out the intake on my 347 from an LS6, to a carb style (remaining EFI). Which one of these intakes are most of you guys running? Pros and cons of both?
Also, in the near future i will be going to a turbo setup on a 370/383/402 ci motor, will both of these intakes work fine for a setup like that?
Im comparing as the Edelbrock super victor is quite a bit more expensive than the GMPP, as im wondering is it worth it for any sort of gain?
Thanks
Dom
Thanks
Dom
After talking to our Edelbrock rep The Super Victor has not been released yet.
You can get the Standard Victor Jr. To get the most out of either intake cam selection is going to be critical as well as proper port matching for the heads you are going to use.
Thanks
Dom
Thanks
Dom
cool, thanks for the input guys.
devon, are you changing out the motor? or just the pistons? plans? I was planning on going with a low compression iron 370ish motor and an 88ish mm turbo....
