My ws6 and fast 90/NW 90 and bellows.
I am having some problems getting my stock bellows over my 90 mm NW tb on my ws6 ta. Anybody using the stock ws6 bellows on this 90mm or did you make one or get mabye a slp one ?And if you got the slp one did you have to cut it at all? if you are using the stock one is there some trick to getting it on there?
I had this 4 inch rubber thing around the garage not sure if its fernco or what.It has rip in the middle. I had to cut an inch or so off each end but it works ok now.
I doubt that stock one would have fit.I did read about guys using the stock bellows but not sure the ws6 bellows is different for the z28 or whatever stock bellows.
Anyway problem solved.
The stock bellow will work. I've got the 90/90 set up and I got mine to fit just fine. I put mine in the oven for a little bit and talked dirty to it and it slid right on. You've just got to be a little forceful with it. But it will in fact work.
Oh, and when you take it out of the oven, try and stretch the opening a little bit while it's still pliable and rubbery. Then stick it on there.
