wideband o2 placement?
is it okay if the sensor that comes with a wideband o2 kit only samples one of the cylinder bank's exhaust, i run duals and the only place where the two exhaust streams meet is in the x pipe. i dont really want to stick a sensor in the x pipe and create an obstruction. thanx
You could run dual WB's.
There shouldn't be much different from one site to the other, but now and again I check my O2's are switching the the fuel trims are simular on both banks. Even if you have a WB on both banks you cant tune one side more than the other anyway.
