LC1 Wideband Grounding
I know most of you ground your LC1s to the back of the drivers side head. does anybody have the spec on the bolts for that?
well, if you still have an egr, or something that threaded there, the bolt hole is the same size on the rear of the heads as well, also you could remove an aircomp bolts, or ps pump bolt. all should be the same, atleast you'll get the size.
