Throttle Cable Help
Throttle Cable Help
I just bought a Power Products 85mm throttle body with spacer for the stock LS1 intake. After putting it on, I realized that the throttle cable is too short when using the spacer. Is there an easy way to adjust the throttle cable?
I'll take a look at that little black box thing. Hopefully that will help. I inquired about any installation issues at time of purchase and I was told that I wouldn't have any problems as long as I had the spacer. I would've bought the 80mm if I knew that I would have this issue with the 85mm.
yea i thought the spacer was to mount the 80mm onto the ls6 intake, i would think with the 85 mm there will still be a uneven transition from your t/b to the intake.
i did see where another member actually grinded the opening on the ls6 intake to match the 85mm t/b, then used the t/b gasket cut to fit to seal it on...
