Wiring up A/F Ratio gauge. Got a question.
The purple wire coming off the autometer gauge goes to the O2 sensor correct? I want to run it to my B1S1(front drivers side) O2 sensor. Which wire on the O2 should I tap into?
Thanks guys,
Mike
Thanks guys,
Mike
Re: Wiring up A/F Ratio gauge. Got a question.
You are correct about the purple wire being the one to connect to the O2 sensor.
Tap into pin 69, which is a purple/white wire on the PCM.
