What puller to remove Powerbond pulley?
Old 06-25-2007, 05:56 PM
Marc '99T/A's Avatar
Default What puller to remove Powerbond pulley?
And where do you hook it? On the back of it on the outside of the pulley, I'd imagine. My 3 jaw puller won't work.
Old 06-25-2007, 11:01 PM
98RedBird's Avatar
It wont take a 3 jaw puller. You actually have to use a steering wheel puller. If you look, the face of the puller has 3 threaded holes in it. That is where you anchor the puller. Then just push off of your crank bolt as you would with a 3 jaw puller.
Old 06-26-2007, 12:38 AM
Krab's Avatar
The powerbond pulley sucks to pull off the crank. You can use a 3-jaw puller, that's what I ended up using to pull one off a friend's car. I ended up placing the jaws on the front lip of the pulley. Yes, there are also holes in order to use a harmonic balancer puller, but the holes weren't lined up correctly on the pulley and I have no idea what pitch the bolt holes are.
Old 06-26-2007, 10:57 AM
Thanks for the tips.
