Help. I pulled a good one.
After recieving my new lid from TSP Friday. I finally had time to put it on my '00 TA today. I had already started the project Saturday but didn't have time to finish. Long story short, I ripped off about a 2x2 inch corner of a paper shop towel and had it stuck in the air hose that was conected to the stock lid over the weekend. When I finished putting the lid on. I forgot what I had done, and fired it up sucking the paper to who knows where.
I shut it down right away. Right away and I could hear a slight sound like air trying to pass through the line . I pulled the hose off of what I guess is an air pump and couldn't find anything.
I then followed the line around to the right exhaust manifold and pulled it apart still without finding anything. Next I re-connected the hose and started the car again. It ran fine and the "pump" was pulling in and putting out air. I then hooked it back up to the exhaust man., put another towel over the open hose (secure this time) and went for a short drive down the steet and back.
On the way back the Check Engine Light came on and the pump is no longer pumping.
I'm afraid to ask, but what did i do?
Re: Help. I pulled a good one.
Sounds like the towel just got jammed in the AIR pump. I wouldnt worry about that to much because if the pump isnt working it wont go any further. When you say shop towel do you mean one like the red shop towels or do you mean like a bounty paper towel for koolaid spills.
I like the Idea of just elemenating it, better than tearing that pump apart. So how do keep from getting SES codes?
Thanks for everyones help.
