LS6 intake swap, now misfire...
Old 08-04-2007, 05:40 PM
f50nut's Avatar
Default LS6 intake swap, now misfire...
Like the title says. Just swapped to an LS6 intake manifold, and I have a misfire on cylinder 7. Code is P0307. Where should I start? About to go check the wires and harness to that injector.
Old 08-04-2007, 05:48 PM
u lose's Avatar
check all wires and connections to the fuel rail. also check to make sure all injectors are in all the way. can't hurt to start there. thats just my .02
Old 08-04-2007, 05:58 PM
f50nut's Avatar
Will do..I should also mention that I just did long tube headers, off road y, !air and !egr. The car hasn't been tuned yet..so here's a stupid question: is this normal?
Old 08-04-2007, 10:39 PM
lgobraves's Avatar
no thats not normal...double check all connections first
Old 08-05-2007, 11:21 AM
f50nut's Avatar
problem seems to have cleared itself up..is it possible to get a misfire after removing egr?
Old 08-06-2007, 05:22 PM
f50nut's Avatar
Just got another code. P0136. O2 sensor circuit malfunction bank 1 sensor 1. I expected the O2's to go out after doing headers. Will a bad O2 cause a misfire?? Help please
Quick Reply: LS6 intake swap, now misfire...
