Custom line locker switch mount
I am not liable for anything that occurs.
So I installed my SLP line locker package and had it installed here:
After I thought about it I wanted a more sleeper style
Plate (GM part # 10280509) only problem is it comes with a Pontiac symbol, oh well I just put a GM sticker over it
GM sticker (GM Part#15223484)
Fog light switch (RPO T96 = GM Part#10273879)
Pigtail connector (ACDelco Part #PT1186)
The parts are pretty pricey but here is the outcome:
Starts with a good ground in the case the green wire there:
Now here comes the difficult part your just gonna have to figure out which wire is which, but here is the break down, run the wire from the SLP line locker package to the switch itself and then one to the ground. If installed correctly you should here the Line Locker activating. Find a 12V source such as the orange wire running to the cigerette lighter. Then activate the line locker switch and attach the wire to one of the remaining four wires left and wait for the orange light to come on thats your wire. Wire everything up and you should be good to go!
The plate with the pontiac symbol before the GM sticker #15223484
Here are some on and off shots as well as the finished look shots:
