accufab 105mm tb
accufab 105mm tb
im running a beck sheetmetal intake with an accufab 105mm tb. i have a mustang 5.0 tps sensor that i have to use on that throttle body. the gm and ford tps sensors both have 3 wires which i have to cut and splice together but i do not know which wires are connected to which?
if anyone has any info or help that they could offer anything would be appreciated.
thanks,
david
thanks,
david
I have posted this question several times and have not got a response. After about two weeks of research I have came up with this:
Ford TPS:
Green = Signal Wire
Red = Constant Voltage
Black = Ground
Chevy Harness Wires:
Gray = Constant
Black = Ground
DK Blue = Signal
I am in the process of installing my motor and have not tested the wire combination yet. On my sheet metal intake it looks as the throttle linkage will be the most difficult thing to adapt. I also bought an IAC adapter that converts Ford IAC to Chevy. Hope this helps.
Ford TPS:
Green = Signal Wire
Black = Ground
Gray = Constant
Black = Ground
DK Blue = Signal
