need help fast!
Old 05-25-2003, 11:17 AM
underageZ's Avatar
Default need help fast!
Today i am going to finish putting in my hooker long tubes and i have a few problems. When i pulled the stock stuff i noticed that there were about 7 or 8 different o2 sensors what one go to were and am i going to need to buy o2 sims i am putting an ORYP on. please help.
Old 05-25-2003, 02:29 PM
01redws6ta's Avatar
Default Re: need help fast!
Two sensors closest to the engine (one on each side) should be the same - four wire flat connector I think. These sensors need to be reinstalled. Not sure, you may need wiring harness extensions to reinstall them. The two rear ones (square four wire connector) are the ones that you leave out and install the O2 simms. They just plug into the harness connector and tie up out of the way. You can run the car without the two rear ones, but it will set a code. You cannot run without the front two sensors, though. GOOD LUCK!!!
