Help Wiring Up MSD Injector Plugs
Old 08-20-2007, 03:37 PM
1TRUESS's Avatar
Default Help Wiring Up MSD Injector Plugs
How did you guys wire these in? Does the common pink wire go into A or B side or does it even matter as long as they are all the same?
http://store.summitracing.com/partde...0&autoview=sku
Old 08-20-2007, 08:33 PM
1TRUESS's Avatar
No one has used these?
Old 08-22-2007, 06:11 PM
1TRUESS's Avatar
Anyone?
How about if the injector connectors are facing the out side of the rails the passenger side pink wires are near the front and drivers side the rear?
Old 08-22-2007, 07:00 PM
LS1MCSS's Avatar
On an 01 LS1, the pink wire goes to the A side of the plug on every injector. Hope that helps you.
Old 08-22-2007, 07:20 PM
1TRUESS's Avatar
That help a lot! Anyone else want to confirm this?
Thanks!
