Need Help with 90mm Throttle Body solution for a 6.0L Escalade
Old 08-31-2007, 10:29 PM
Bismarck's Avatar
Default Need Help with 90mm Throttle Body solution for a 6.0L Escalade
Folks, I am having a whipple installed on the 2006 Escalade 6.0L but having a hell of a time finding a 90mm T-body solution. The ones off the Vettes do not have the right connector.
Was told maybe teh SSR trucks may fit. But could not find a certain answer
Anyone has a recommendation?
Old 09-07-2007, 04:34 PM
SS_bnoon_SS's Avatar
Dude, hit the tab at the top for Performance trucks and check/search the forums there. PM a member Dr X for his 90mm drive by wire harness adapter. Works VERY slick to convert the vette/GTO/ETC 90mm TB to your stock wire harness.
Just don't get a TBSS throttle body yet because they're different than the vette's and don't work with the DR X harness for certain (the TBSS requires a different voltage signal internally, a solution is in the works for the TBSS conversion but it hasn't been tested yet).
Old 09-07-2007, 11:57 PM
Bismarck's Avatar
Thanks bud, apparently he got a system that works... Ended up using the Corvetter 90mm T-Body.... with a connector adapter. I have the link...
